Installed Universal Flowmaster 50 HD muffler
Stewi
So I spent a few days searching for a muffler for my 2014 Express CC. I finally settled on the Flowmaster 50 HD but I couldn't justify spending $360 on the direct fit model, so I spent $150 on the universal muffler instead. I'm a bit of a hard core DIY'er. My previous project was a 99' Mitsu Galant that I installed a complete Mitsu Evo drivetrain in and converted the car to AWD in my garage with a few jacks and a welder. So I figured, how hard could it be to install this muffler?
So here is the muffler itself unboxed
I measured the outlets on the Flowmaster and the distance from center to center was only about 5/32" shorter (closer together) than the stock muffler. I also measured the overall length and decided the easiest way to make this work would be to mimic the stock muffler overall length, for an easier install.
I started by welding 2 1/2" ID to 2 1/8" ID adapters on to the outlets of the muffler. I cut two slits into the smaller side so that I can clamp them down good to the stock pipes. Once I had this figured out, I lined it up next to the stock muffler and took measurements to determine how much tubing I had to add on the inlet side.
Then welded a piece of 3" steel tubing to the inlet side of the muffler and a 3" OD to 3" ID transition adapter. I also cut two slits into the larger side of the adapter.
I just welded this up quick, if I had been welding stainless I would have taken the time to clean the joints more thoroughly and back purge the TIG weld for a nicer looking and corrosion resistant weld.
Once I had the overall length exactly the same as the stock muffler, I had to figure out what to do about the hangers. If I had a working MIG welder (mine broke), I might have just did the hangers with the muffler on the truck already, but since I didnt have a MIG and since I absolutely hate trying to use my TIG laying on my back, I came up with this solution.............
I built a quick jig using the stock muffler as my reference to locate the hangers. I used the outlets on the stock muffler to mount the jig since I knew the outlets on the flowmaster were in the same position length wise and only 5/32" closer width wise, which has no effect on the hanger location.
Then I bent up two pieces of 1/2" steel rod to make my hangers. I just put the rod in a bench vise, hit it with 200 amps from the TIG welder for about 10 seconds to make it red hot and hit it with a mallet to get a 90 degree bend. I could have heated it with a torch but I already had the welder setup and I was being lazy.
I used the jig to locate the hangers, used vise grips to hold them in place while I welded them and then used a piece of rod to join the hangers as a brace. This jig will come in hand as I will be helping two of my friends install mufflers similar to this on their 4th gens in the near future. I also ran a small bead of weld around the ends of the hangers to help them stay secure in the rubber mounts.
After that I just sprayed the welds with some high temp rustoleum flat black paint and installed the muffler. It fits like a glove.
I purchased the 3 adapters and muffler clamps from the local AutoZone for about $20 and the 1/2" steel rod from Home Depot for $10. The piece of 3" tubing I had laying around in the garage, that was free. So I'm into the whole muffler job for about $180 and 2-3 hours worth of my own labor. At the end of the day, I'm very happy with the finished product. I tried to link the video/sound clip via photobucket but it wont work.
Nutshell
Nice work!!! How's it sound?
clh1220
st Louis
You did a good job, no doubt about that. I bought my direct fit for 270 total. so if you compare it mine you saved about 90 bucks and if you throw in the difference in cost for the better band clamps it's less than 90. That is the stainless muffler you got.
S
Stewi
I wasn't able to find the direct fit for under $340-370 when I was looking. Also the universa 50 HD is mild steel, not stainless. It wouldn't matter either way since the adapters aren't stainless, but for what I wanted it to do, it works.
clh1220
st Louis
You did a great job. But most won't be able to do all that. If they look they can find the stainless 50 hd on eBay. That's where I bought mine. I called a few muffler shops and to get the non stainless installed they wanted around 350 to 400. If anybody wants the name of the seller pm me.
S
Stewi
That's a crazy price from a muffler shop. I'm in Metro NY and it would be about $100-$125 to have it installed at a normal muffler shop here. The stainless 50 HD you're talking about is universal or direct fit? Flowmaster doesn't list a universals single inlet dual outlet stainless model on their website.
S
Stewi
Nice, yeah I just wasn't looking to spend that much $$$ on just a muffler.
clh1220
st Louis
Oh I got that. You saved money,I just don't think other people will save as much as you, since you can do the welding. I need a stainless here other wise it would rust out in a couple years , with the winter salt.
