Installing 4 channel amp
AustinSpeers
2019 Ram 1500 Classic
Hey guys,
I have a 2019 1500 classic, and I was wondering what do I need to install a 4 channel amp? I’ve seen so many YouTube videos of people installing them all kinds of ways. I already have a mono amp with 2 10 inch subs along with the 2 channel pac LOC. can y’all tell me exactly what I need and if you have something similar to mine please share what kind of equipment is in your truck
Thanks
A
AustinSpeers
I forgot to mention I originally had the 5 inch uconnect and I just installed the oem 8.4 4c uconnect
Kalill Nieto
Fort Lauderdale
The best way is going behind the radio and grab the signals to convert it in rca and from there take the speakers wires and run those wires to the amp or a summing. If you dont want to cut the wires you must get a male female plug harness. Let me show you...
A
AustinSpeers
The best way is going behind the radio and grab the signals to convert it in rca and from there take the speakers wires and run those wires to the amp or a summing. If you dont want to cute the wires you must get a male female plug harness. Let me show you...
I can do all that I got no problem cutting the wires and making the splices myself, but can I just use this LOC https://www.amazon.com/dp/B00DHUA3W0/ref=cm_sw_r_cp_api_glt_i_8P7DG90YP1RXP9REZXGW
Or do I have to buy the one on the pac website and use that one that comes with the harness because it’s a lot more expensive. I also see a lot of people using the LCi7
Kalill Nieto
Fort Lauderdale
You can use this harness and cut the speakers wires. Add the high to low converters to rear and front and take the speakers wires, using a speed wire to run the speakers wires to the amp. To turn the amps on you can take the signal from the left power outlet in the dash.
Kalill Nieto
Fort Lauderdale
