Installing aftermarket stereo
Ramechanic
Canada
Hi, I've had problems with my factory stereo so I've decided to install a single din Kenwood. I'm also adding an amp and sub. What Im not sure of is where can I get the switched power for the amp. Thanks
Ramechanic
Ramechanic
Canada
I should add that both of my lighter plugs have power with the key off.
Ramechanic
Ramechanic
Canada
Also on the receiver plug there is two wires with 2.5 volts power, what would those be for?
troutspinner
Gilbertsville, Pa
2019 Big Horn Crew Cab
What model is the head unit? There is a possibility it has a remote on it that can trigger your amp to turn. This is not to be confused with amp power, that should be a separate fused line that you would install directly to the battery. A model number should also be able to tell us what those 2 lines are for, though they are probably pre-amp outs.
Ramechanic
Ramechanic
Canada
The aftermarket is a KMM-BT308U the factory was an RES
Ramechanic
Ramechanic
Canada
Also I am referring to the plug on the truck it's the two wires on the plug beside the battery wire.
Ramechanic
Ramechanic
Canada
I just thought of something, I should check the lighter plug again because I think it had power because of the delay after the key is turned off like the radio.?
baum
savage, mn
2015 Laramie
aftermarket radios have a remote turn on for this purpose. use that wire. its usually blue/white wire coming out of the radio (aftermarket)
troutspinner
Gilbertsville, Pa
What Baum said. I looked up your HU and downloaded the manual. You do have an amp turn on lead.
Ramechanic
Ramechanic
Canada
Ok well that makes it easier, sorry def not an audio guy. I will use that wire then, thanks! As a side note my lighter socket does shut down with the key off.
