Installing Fox 2.0 Coilover Help
will846
I'm currently installing the coilovers. My main question is their a difference in drivers to passenger side? Having issues trying to make the bolts line up on the lower control arm. Any help is appreciated.
madrock
If I remember correctly, you should be able to turn the body so that the lower mount lines up.
novelmike
Central California
There is no difference. Like he ^^^ said, you may have to turn it a bit to get it to line up.
Mine went in no problem.
W
will846
Thanks both of you. I was able to turn the bottom yoke and it fit.
