Intake vs roller rockers?
Deepfried
Oklahoma
Which mod would be better to pair with flyinryans SCT tune? A Hughes f1 air gap intake or a set of Harland sharp 1.7 roller Rockers?
dapepper9
Iowa/Nebraska Border
5.9L V8
Roller rockers will be easier to install and give your truck more pep. Intake will lose a decent amount of low end tq and make your truck slow of the line without supporting parts
Deepfried
Deepfried
Oklahoma
Well I'm going with the Harland Sharp 1.7 Roller Rockers. Is the pedestal mount an easier install than the stud mounted? Price isn't an issue I just want whatever is easiest.
And I've seen in a few places that our kegger intakes are actually pretty good at low end. So I was already leaning away from the intake.
BBartow
New Port Richey, Florida
5.9L Magnum
#S70037 is what you want
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
If I remember right I went pedestal mounted 1.7 Harland Sharps. I installed mine in an afternoon. Gave the truck a little more sound and deff some more up and go.
Sent from the howitzer
Merc225hp
NA
truck
gas
No drilling is needed if u use the right stud kit. Crane Rocker Arm Guide plate Conversion Kits 36655-16 needs no drilling whatsoever.
Deepfried
Deepfried
Oklahoma
The pedestal mount HS doesn't require drilling does it?
Merc225hp
NA
truck
gas
$380 for the two kits vs $408 for the hs kit thats non adjustable. All prices are from summit.
Rustycowl69
2001 ram 3500
V10
late '80's, my friend with a 70 hemicuda, asked me to spot face his oem rocker arms, and install Crane "computer designed" adjusting screws, 3/8" NF, thread, with locknuts. Well those male threads were like 0.015" too small. You could just about put them in sideways. OK, slight exaggeration, but they defintely would have stripped the internal threads in the oem rocker arms. That's the last time I ever purchased/installed any Crane equipment. Once burned, twice shy. Just saying.
Merc225hp
NA
truck
gas
I can knock just about every aftermarket supplier for some **** or another. I have a set of new HS 1.7 here that are total ****. So yea I can say the same. I have about 125k miles on my Mopar rr's and stud kit no problems at all.
Deepfried
Deepfried
Oklahoma
What's wrong with them? I definitely want the best quality I can get.
Merc225hp
NA
truck
gas
Bearing's are ****** in a few of them, from new. Like any part u get bad ones sometimes.
Reticle918
