Interior LED’s
Hookedup87
Long Island
I have switched all of my interior bulbs to LED’s except for vanity mirrors, glove box and footwell pods. Any tips or how to’s, tricks, etc, to doing these?
The glovebox uses the 194 LED bulb that will fit in the maps lights. The footwell lights can use the same 194 or 921, the only difference is the 921 are a bigger bulb but the base is the same.
If I remember correctly these are the ones I used in the vanity mirrors: https://www.superbrightleds.com/mor...b-3-smd-led-miniature-wedge-retrofit-car/228/
They're cheap enough I bought two different styles in case I didn't like one or the other.
Hookedup87
Hookedup87
Long Island
Thanks. Very helpful. Do you remember how you changed the ones in the footwell? Does the lens of the pod come off or do you remove the wire and bulb from the back? And the vanity mirrors. Did you use a small screwdriver to pop out the lenses?
with mine ('15 model yr), yes and yes
The footwell lights the cover pops off and the vanity mirror light lenses come out. The glovebox light you pull the whole switch assembly out from the front.
I doubt much has changed with the lights since then.
KAKA
