Want to Drive
I have a 2014 Ram 1500 quad cab sport with 77,000 miles on it. Last night I was driving home and the EPS went out. The steering wheel ****** slightly and a "Service Power Steering" warning came on the dash. The truck was very difficult to steer but I was able to get it home by taking less busy roads and making wide turns. I spent a few hours reading about the EPS and what the issue could be. I was hoping it was a fuse or the belt inside the unit as these are things I could fix without replacing the whole unit. I started the truck today and no issues at all. I took it for a short drive and it steered completely normal.
So what do I do next?
I'm assuming that neither fuses nor the belt are the culprit because the issue went away today. If a fuse was blown or the belt was broken I would expect to get the service eps message.
This leads me to believe the issue is in the EPS control module/board. A lot of the issues I read regarding an issue in the EPS control module/board were people experiencing the issue is cold temperatures. I'm located in FL. It's been 70 - 80 degrees for the last several weeks here. The truck is kept in a garage and I haven't driven in the rain in several months so I don't see how any water could have gotten in.
I'm hesitant to drive the truck because who knows when the EPS is going to go out again. At the same time, it's my only vehicle and I can't just not drive it.
Any suggestions from the forum? Any chance I'll get lucky and it was a one time thing?
