Armenta_1579
I have a 2003 Dodge Ram with a hemi 5.7L
I have already checked all fuses, swapped out relays, checked visible grounds and battery cables, checked battery, (battery is good) checked ignition switch. The problem I’m having is, the truck won’t crank not start whenever it feels like it. Whenever it doesn’t crank, fuel pump doesn’t work, gauges on the instrument panel don’t work(lights on dash do work along with all other interior lights and radio) I don’t get any messages on the instrument panel unless I do the check for chassis codes step. I sent the pcm to get checked and I was told it was still good and with no problems, I drove the truck around today with no problems, got home, turned it off for aprox. 5 minutes, went to go crank it back up and gave the same condition, needles wouldn’t work, no crank no start. Waited for about 20 minutes and everything worked again. Checked temperature gauge and it was at about 1/4 of the way. If anybody could help me I would greatly appreciate it.
