Intermittent starting problems
Doomprayer
Hemi 6.7
I have a 2019 Ram 2500 gas, I’ve been having issue with the truck not starting, sometimes says key fob not found or just takes 10-20 pushes on the push button in the cab. The battery is good and all the electrical works just doesn’t start at times. Sometimes from sitting overnight it won’t start. Tested the starter and it’s good as well. Replaced the key fob battery as well. Any chance anyone knows of a similar issue?
ibike
Navy Badge
Tennessee
I’ve seen some folks have put “bling bling” around their key ring start button. Have you added anything to the dash area that might disrupt the rfid signal? The ones I’ve seen are not Rams, and it’s usually a ring around the push button. Just a suggestion.
Reticle918
