IS A RELAY REQUIRED FOR LED REVERSE LIGHTS ON BUMPER
dieseldave
Little Suamico
WHEN INSTALLING TWO LED REVERSE LIGHTS TO MY BACK BUMPER, I WANT TO TAP THE WIRES TO MY TRAILER WIRE HARNESS. IS A RELAY REQUIRED?
bm02tj
B C Canada
Tap into trailer plug wire as it is on separate relay
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I put the small Rigids in my 2019 Classic bumper...holy smokes they are bright.
Graygoose
Oklahoma
Convert, for now.
small
The Curt wiring harness. Let me see if I can find it.
hemi-ram2
converse tx
2021 Ram Laramie hemi CrewCab
2021 Ram Laramie 7 pin connector center wire is brown on truck. Look under truck there is a plastic retainer just pop it off and confirm. Thanks
Brian2081
Weatland Michigan
I took the pin out of the 7 pin connector, ran a wire through the rubber seal around the wire I removed and souldered it to the pin and reinstalled pin in connector. Did same with ground wire.
May be different than yours, but same idea, this way your not hacking into stock harness.
That link is for a 4 flat, the Curt 5 flat already has the reverse wire tapped:
CURT 56584 Replacement Vehicle-Side 5-Pin Trailer Wiring Harness https://www.amazon.com/dp/B007EA6WQU/
