Has the tow package. The tow mirrors don't have a power fold option.If that picture is the truck you are looking at, it does have trailer brakes, I can see the two buttons on the center cluster that is trailer brakes.
I find it hard to believe that it would not have power fold mirrors. A small center button on mirror controls
I had a 2017 Longhorn and from your pic's it is a Limited ... The Longhorn in 2017 had the "Longhorn" chrome badge on the front doors and one on the tailgate ... It also had "Longhorn" above the glovebox and also on the console lid where the one in your pic's says Limited .. The Longhorn was a higher version of the Laramie ... I have a 2020 Longhorn now and is still referred as a Laramie Longhorn, however in 2021, they changed it to a "Limited Longhorn" ... Hope this helps ...so my 2015 ram 1500 bighorn rambox been having some weird transmission issues so i decided too trade it it i always wanted a Laramie .............. local dealer as a 2017 Laramie Loghorn but allover it has limited on it .its loaded with ever option under the sun except 2 i can see no front parking sensors ( has rear ) and no folding mirrors im sure theres more .anyways it has 42k on it .but has a check engine light on and says its air suspension and trailer brake issue i seen no trailer brake on it ( if it still the old type that would mount to bottom of dash with a knob on it anyways ) . so should i be weary of those issues .they say there going too fix what ever is it. i haven't bought it yet but did put 4k down on it.
i was also surprised at no folding mirrors and not a fan of the ones on it prob change them laterIf that picture is the truck you are looking at, it does have trailer brakes, I can see the two buttons on the center cluster that is trailer brakes.
yea i have it in writing on fixing everything and have a warranty with the truck as well its at the body shop now getting repainted in several places cause the scratch guy ( new guy they tryed ) messed it up bad so its getting fixed on there dime the right wayWell you why he traded in that truck. Air ride doesn't age well. I would not sign till all is fixed. If they say fixed but it takes 100 miles before they can reset computer then let some salesmen use then clears error code. Nothing worse than a beautiful truck that is trouble they can't figure out which is why I got rid of my pos ford. Good luck.
It's very fixable if you have the knowledge to do so. Unfortunately if you're relying on the dealer to repair it, yes, you could buy another truck for the cost of servicing the air ride repeatedly. Another option is to remove the air ride and go to a coil spring. It's an easy swap and not that expensive compared to fixing the air ride multiple times. My 2016 still has trouble free air ride. But I've already prepared myself that when it fails (depending on what fails) I'll swap it out for coil springs.Air ride is not fixable. It is bad design to start with.
Don’t think it’s a longhorn. Not brown interior Does have trailer brakeso my 2015 ram 1500 bighorn rambox been having some weird transmission issues so i decided too trade it it i always wanted a Laramie .............. local dealer as a 2017 Laramie Loghorn but allover it has limited on it .its loaded with ever option under the sun except 2 i can see no front parking sensors ( has rear ) and no folding mirrors im sure theres more .anyways it has 42k on it .but has a check engine light on and says its air suspension and trailer brake issue i seen no trailer brake on it ( if it still the old type that would mount to bottom of dash with a knob on it anyways ) . so should i be weary of those issues .they say there going too fix what ever is it. i haven't bought it yet but did put 4k down on it.
