Is this a possible combo?
JCARTER7
NJ
I have a 2011 1500
I want to get some lift out of my truck but nothing crazy.
I am going to install bilstine shocks in the front set at 1.8
Then I wanted to know if it's possible or safe to also install S 2.5" Suspension lift kit as well.
Front
2.5" lifted strut spacers
Hardware
Rear
1.75" coil spacers
So 1.8 lift with shocks then 2.5 with spacers in front = 4.3 inches
And rear would be lifted 1.8 inches
Truck would be level
Here is the link for a similar kit:
http://www.roughcountry.com/dodge-s...o1r1Dha6tldGdtUtQ_9NWrFO99z9rMVroMaAugb8P8HAQ
I tried searching the forum never came across something exactly like this. Any input would help.
Thanks guys!
xrsman
Ontario
3.0 Ecodiesel
It's that cut dry? Lol
Why?
I looked at doing the same thing when I was going to lift mine. I asked that question on here and guys said that it was a bad idea to stack bilsteins and a spacer on top
chipmaker
AZ
On all 3 major Ram boards you will find "no stacking level kits" taxes out the CV joints. Everyone comes on here wanting ~ 4" of lift for cheap, just not possible. I raised my front with Bils and I'm running 35s. Bils were $200.
atticusfaul
Boise
Level plus a small body lift will get you want!
SuperTrooper
Douglas, GA
Just out of curiousity, would stacking bilsteins on say .7" with a 2.5" to keep my front end leveled after the installation of a heavy bumper such as a Ranch Hand be ok?
Little Red
NY, USA
Why not just max out your bilsteins? You'll achieve the same results, increased height to compensate for the droop caused by the heavy bumper. You won't however have to worry about killing your cv's and balljoints.
BOWERSFJ
Uniontown OH
1.8" is not a choice with Bilsteins . . . 0.7" 1.4" 2.1" 2.8"
SuperTrooper
Douglas, GA
That's a possibility. I'm just not sure how much the bumper is going to drop my front end down. I want to keep it as level as possible, or even a tiny bit higher in the front.
