Issue on first start of the day
Tyler Yates
Iowa
As the title states, first start of the day truck will crank, try to start, sounds like its flooded. If i give it some gas peddle it usually will fire up otherwise ill just turn the key to start it again and it will fire right up no problem. Not a single other problem than that. No lights, weird idles, nothing, nada. I have ordered some spark plugs just for ***** and gigs since im at 50k. My tuner did recommend unhooking the battery for a bit to let it reset itself. If tomorrow morning its fine ill let yall know but for now... any thoughts?
Brandon-w
Yukon
2015 Ram 1500
If you have a code checker see if there is a soft code. Sometomes I get a fuel pump code. Sometomes my truck doesn't like to start either but I think it may be because of the lumpy cam sometimes.
Tyler Yates
Tyler Yates
Iowa
My engine is stock besides the tune so far. Ill check it after work.
southalum
