Issues with left LED tailight going out on 2017 1500 Rebel
Jimsin
Ontario, Canada
So my 2017 Ram Rebel 1500 has been having an issue with its left rear LED light going out but all LEDs in the light work. Dashboard notification is up, when I use left turn signal, it flashes the fast "indicator out" quick click and when using the left tail light it works fine for about a minute and then fades out dimly and goes out, but if I restart the truck, it starts working again.
All lights on the truck work, including top brake light.
Any suggestions would be great.
Thanks
MB_RAM
California
V6
I had this problem after replacing my LED tail lights with aftermarket (2020 1500). "Left turn signal out." It was driving me crazy! It "dinged" and the dash lit up nearly every time I hit the brake. Everything worked perfectly, but the warning was going off and I'd get hyper blink inside for 2 months. Dealer told me there's nothing they could do. It was bc the system didn't like my aftermarket tail lights (voltage blah, blah, blah). I was desperate!
SOLVED... I was low on fuel. the "Low fuel" warning light kicked on. "Left turn signal out" light stopped. I was afraid to refuel, but of course I eventually did. The warning never went off again. I don't know why, but I'm telling you that's what happened. Give it a try!
mvm2
