jet performance?
brandonb1481
Southwest Ohio
5.9 magnum
so far its not impressing me. i bought a jet performance module for my 94 dodge ram. well first off when i went to screw in the metal thread to make the original bolt to reach to tight it up. barely turning it, it broke off. inside of it... had to carefully drill it out. and we found a alternative. but when i put the module in. hooked the battery back up and everything. it wouldnt start worth nothing. not at all. it did require a 180 degree thermostat. and at least 91 octane fuel. i didnt have those. i just figured i wouldnt get the max performance out of it until i got the thermostat and go fill up with 93. is that why its not starting? or is the brand a joke?
SmokedRam
Zephyrhills, Florida
All those things are a resistors IIRC....much like a power wire, etc. The best way to tune these trucks is with programmers. Otherwise, you're just ******* away money.
