Was pondering the Idea of switching the the gear selector knob to a shifter when I do the console. Has anyone ever done this?
Thanks, I was just pondering the thought. It took some getting use to the rotary knob
Isn’t possible may be harsh. Has anyone tried retroing a shifter from something like a Charger or Grand Cherokee, that also uses an 8 speed, but uses a more conventional shifter? It wouldn’t be a direct drop in, and would certainly require fabrication, but electronically, it may be compatible.This isn’t possible. The 8 Speed transmissions or electronically shifted, which wouldn’t work with a column or floor shifter. You could easily do it with a 6 speed, though.
Sent from my iPhone XS Max in my 2013 Magnum 4.7L V8
