Just died
ralaubach
CA
2007 Ram QC
2007 ram QC 5.7L
Driving around town on a somewhat hot day, i went from about 50mph and hit a stop light. as i started to come to a stop the truck just died on me. then today i was dumping some trash in the dumpster, left it run, and then went to get in and drive away, put it in drive and it died on me again.
no crazy sounds or vibrations. just an all of a suden low idle and then dead. both times it has started right back up. I always run 89 octane at least. currently it has 91 octane in it.
Lastly i did just use my bully dog tuner (yeah yeah I know crappy tuner) and went from a stock tune to the performance tune.
anyone have any thoughts on this?
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I've had the bullydog on performance since I bought it. With no problems. Try doing an update on the tuner, if that doesn't work I'd put it back on the regular tune.
Sent from my ADR6350 using Tapatalk
R
ralaubach
CA
2007 Ram QC
no code. but if i am not mistaken you are supose to replace the EGR at 60,000 right? never did get around to that one and i am at 65xxx... :S
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
There is no set mileage to replace the EGR valve. Replacement is only needed if the valve is faulty.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Check your plugs, check your TB. Did it happen right after the tune? The PCM could have not rewritten fully.
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
Check the throttle body. If it's dirty, give it a good cleaning.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I read some reviews on the tuner, if there aren't any codes then you need to call bullydog and talk to one of their tech's... They had to rewrite a tune for a guy on his bc it was acting up like that.
1AJeremyD
Mass
Ya I would say if the only thing that has changed is the tune then its the tune itself. Maybe there is a fault from idle and 0 TP
