K & N filter
brocker1234567
Kentucky
5.7 Etorque
a week ago I installed a drop in K & N air filter in my 2021 Ram 1500 5.7 E torque…. It changed the entire dynamics and sound of the truck and not to the better either… Im old school I was flipping carburetor housings over on gt mustangs to get that throaty roar years ago. But, this was different!!! It gave it a throaty sound. Butttttt, it also messed w engine tach response and produced a sound that basically seemed to come from the drivers side of the motor. It was sound like the exhaust was loose!!!! Is this due to the sensors getting too much air or what would cause this???? Anyone else encountered this ????
VShagios
Kansas City
In any vehicle, when you change to a K&N you have to let the cfm sensors re-calibrate. On Ford, you disconnect the battery for a couple minutes and that resets the system so it can calibrate. If you don't reset the sensors, it will calibrate but it takes longer. I just put a drop in K&N in my Ram 1500 5.7 Hemi and it took about 100 miles and its running great, mpg ticked up about 1mpg.
HuskerRam
Air Force
Tucson, AZ
3.0 Ecodiesel
Does it have the same symptoms when you put the paper filter back in?
Kickboxer
ND
5.7 Hemi-non-Etorque
BS to a large degree........:(
JW2 Innovations
Supporting Vendor
Sparta, TN
2016 Ram 2500
I've used them on a few vehicles and never had a weird exhaust sound. Go back and check your install. Might just be something that needs to be tightened. Worse case from previous post, put stock back on and see if it goes away. I'm betting on something loose. Btdt. :)
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
I have always experienced more of an intake sound but not what you are describing. You are going to get a lot of haters on this subject but I have been using K&N filters for over a decade & never had any issues. The performance & mileage is very little but I have a forever filter. Just clean it once or twice a year. If you keep your vehicles long enough the pay for themselves.
Tray Burge
On the porch
Mine came with the K&N kit.
It was the first thing I yanked off, didn't need the hot air sucker for sure.
Go with the Vararam if you want a CAI and you'll love it!
zrock
canada
K&N is junk, lots of posts out their showing they allow fine dust into the engine.. No benefit what so even on a stock engine. Before anyone says it yes tey are used in the racing world but they also rebuild a engine after every race so they are never going to se a dusted engine
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
K&N is just old timey oiled toilet paper (cotton fiber). It is a rock catcher meant for the relatively clean air confines of racing - not truck duty.
Use a paper or synthetic (preferred) media. Lots of Google articles about this.
1 MEAN66
Waterford NY
Hemi 5.7 VVT-MDS
I agree - I have, and have had K&N's in everything I own and have owned, Even our riding mowers. Never had that issue. Double check your work, have someone else listen to it to help pin point it, and its location.
Mopar440
Ontario, Canada
Hemi 5.7 (345cid)
I've run K&N in my vehicles for about 30 years and never had an issue. I put on in my 2017 Hemi Ram and no issues. Performance picked up at touch and fuel economy increase a touch but too about 200 Km before I noticed the improvements. I keep it clean and keep it oiled (lightly).
HANSOME
I just installed a kn63 series drop in, and got no changes.
Kickboxer
ND
I dropped one in and gained almost a gallon per mile average. Win.
Another BS'er, new member. Don't try to troll on here. Almost..............
Artwerx
Southern California
Haters gonna hate. It's absolutely true. What exactly do I gain by lying about this again...?
I was at 9.8 ampg and since I dropped in the K&N I'm at 10.7-10.8 ampg. I don't know how that's "trolling". Maybe you need to rtfm?
Dean2
Near Edmonton
I would not give up top notch filtration as I use my truck in dusty conditions a lot, and you definitely do give up filtration with the K&N. There are also a ton of independent test reports that show other ill effects of them, depending on filter, kit used, operating environment, etc. I cannot believe there has never been a class action suit against them.
2Tallguy
San Diego
5.9 diesel
a week ago I installed a drop in K & N air filter in my 2021 Ram 1500 5.7 E torque…. It changed the entire dynamics and sound of the truck and not to the better either… Im old school I was flipping carburetor housings over on gt mustangs to get that throaty roar years ago. But, this was different!!! It gave it a throaty sound. Butttttt, it also messed w engine tach response and produced a sound that basically seemed to come from the drivers side of the motor. It was sograb a freshly oiled K7Nund like the exhaust was loose!!!! Is this due to the sensors getting too much air or what would cause this???? Anyone else encountered this ????G
Project Farm UTube tested a number of dry and oiled filters. The K&N rated rock bottom on filtration and best for flow. Wonder why?
ChloeBrooks
