Key FOB - Proximity?
turkeybird56
Central Texas
The link Turkeybird56 gave above for the kit is quite reasonable considering today’s prices. I’m assuming it contains everything needed to add the proximity handles to a 5th gen truck. I have a 2018 4th gen BigHorn and added Keyless and Go myself in 2019. My parts alone were almost a grand including the push button start and new fobs five years ago. First world problems LOL
TO ANYONE: Before U just HIT this link and order: U need to research the site and make sure it is compatible to your truck/year. I did not go crazy on web site. There may be other similar offers-parts but different parts depending upon the year of your vehicle and trims etc.,. .
TotallyHucked
Gainesville, Ga
2017 Sport CCLWB
Yup, that's how it is on my wife's Ford Expedition. I still wouldn't buy a higher trim level just for that though.
No, I agree with you there. But I was already shopping for a Sport with the R/T hood so once I was there, just had to find one with that option along with other must-haves.
Hardracer
Swfl
2010 1500 laramie 4x4 crew cab
That is an option, part of a package on the higher end trim models. Yes, U have to push button to open door. What you are looking for is Passive Entry System, see URL:
ADDED: Beware: Your Key Fob can transmit a long distance. I can be in my kitchen, which is opposite the living room. LR to main door out to truck. Like more than 50 feet away, and hit key, and house door is closed. I also have a steel roof which dampens signals, and I can still open and remote start my truck. SO when U R in an area that U have to be concerned about PPL trying to steal signals covertly to steal stuff, maybe walking around with your keys in a Faraday bag and not remote starting and opening your truck from far away may not be a bad idea. Just IMHO.
I've been well over 100yds away and forgot to lock my truck..still in line of site of my truck...and locked it..
Work in a big steel building been able to remote start more than 50yds away...tripped it 1 day in my pocket...fellow worker comes up to and said your truck just started...I said waaaaa?
turkeybird56
Central Texas
YUP, they are potent buggers, why in Big crowds, city, wateva, Faraday Pouch a Good Thing.
hamco
Saskatchewan
I've got a problem with my smart fob not working after shutting off my 2021 3500 in certain location in our major city. Dealer said same issue in our other major city. Key FOB NOT Detected even when holding it on the start pushbutton. Dealer tested FOB and had transmit power up to spec. Seems like the passive signal is weak from FOB, and truck is overwhelmed by radio interference in some locations. Would be nice if FCA could address this issue with a different frequency, or a work around, because in our cold climate I don't want to get stranded. A conventional key switch would have been helpful. Service tech had no solution. He even had to rescue his daughter when she got stranded. Is 5G the culprit?
KeithP
Hemi 5.7 VVT
A couple years ago when I had my 19 1500; parked in a grocery store lot, came out w/grocerys +\- 20 minutes later. FOB was dead, or so it seemed, wouldn’t unlock the doors, wouldn’t start even when holding it on the start button. Two other vehicles next to me, both GM products, had the same problem. We were parked within one spot of one of those solar powered portable parking lot CCT towers. After about 15 minutes of frustration from all of us all three vehicles started and all was normal. We figured the tower was uploading data and blocking our FOBs.
demech
Spencer, IA
In my previous pickup, a Ford, it operated like you suggest. If you got within 15 ft the door locks/unlocks. It doesn't work that way on my RAM. With my RAM I have to grab the door handle to unlock and push the button on the door handle to lock. It's one of only two thinks I preferred about the Ford..... Come on RAM! Figure it out!
RamDiver
Marlborough, Ontario Canada
2021 DS
It sounds very much like you're comparing apples to oranges, from what you're describing.
Are you referring to a proximity unlock system or a remote unlock system?
Are you unable to use the remote features from 50' or 100' away?
I can lock/unlock/remote-start or hit the panic alarm with my '21 Warlock FOB, usually from a couple of hundred feet away. If you're unable to use the remote features from a distance, something is not working correctly.
A weak battery in the FOB, defective FOB, an RF module problem, local radio frequency interference (RFI), or something else is causing this system to not function correctly.
Have you escalated this basic remote function to your dealer?
demech
Spencer, IA
I am talking about proximity locking/unlocking. My FOB works fine. With the proximity unlock/lock with my Ford the FOB never left my pocket and I didn't "forget" to lock my pickup...
Upper Midwest
2021 Night Edition
5.7 E-torque
I just bought a 2021 RAM and I couldn't believe this feature is not standard. What a joke! This should be something you can program or turn on and off. I have a 2013 Grand Cherokee Laredo and this feature was on it. It was damn nice! Being able to just walk up to the door grab the handle and open. Come on Chrysler!!! They should also offer leather on the Big Horn. Lots of guys want leather but don't want all the safety/tech crap that comes with the Laramie and higher trim packages. Some of us actually USE our truck for what it was designed for and get dirt and grime and grease on our seats!
suicideking
suicideking
Riverside, CA
Same with my wife's 2013 Prius with pretty basic options.
Hugorhr7
