Kicker amplifier wiring help
Aikido187
I am wanting to install the Kicker KX800.5 amplifier and a Kicker Front Row DSP. I think I have all the wiring figured out except for the front speakers. I'm running Kicker KS35 3-1/2 in the dash and Kicker 6.5 components in the front door. I am not sure if I want to just tap into the factory wire or run new wire, and that's where I need help. I'm confused because the front door speakers and front panel speakers are wired together. I have a 2014 Ram 1500 with the base audio system. Anybody got any advice?
Etroze86
Grand Forks ND
I like to run new wire, but I also change up equipment enough that I need it for when I throw serious power at a set of speakers.
The next thing to think about is how the front row controls what's going on with those speakers like time alignment, level adjustments, and eq. Again I would run new wire to take advantage of it.
Maybe gray graygoose will chime in on that part though.
Sent from my SM-G920V using Tapatalk
adrianp89
Tampa Bay, FL
I would drop new wire for the dash speakers since it is as simple as dropping wire down a hole, and this way you know 100% it is separated from the doors. For the door speakers, it is useless in 90% of applications. Unless you running 150w+ to each door, it is a waste of your time and money.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Yes, add separate, as the Front Row you will be able to dial the dash in a lot better now.
A
Aikido187
I should have elaborated on my set up. I have 3.5 in dash, 6.5 components in the door, and 6x9 in the rear. I have a 5 channel amp and I don't know how to wire up the front door speakers and the 3.5 in the dash. I would like to use 2 channels on the amp for this since my other 2 channels are powering the rear.
joshhhh
