Kleinn 4th gen 1500 specific air horn system & on board air
Status
Not open for further replies.
kohersh
vehicle specific for all 1500 DS Rams (except those with a winch up front).
I bought this from Kleinn and did their 'beta testing' and made a couple youtube videos about the system on my Sport. Removed it when I was an inch away from trading the truck. Kept the truck instead and just don't feel like re installing it since my wife would beat me upside the head anytime I honked the train horns anyhow. I do miss always having 3 gallons of 120psi of air onboard though. Everything is in good working order and good cosmetic condition- but It has been on the road.
So this fits up between the front sway bar and behind the front bumper cover. Literally Bolt on and zip tie it up, without modifying the frame or making new holes. It is SLICK
All of my wiring is terminated to length with marine grade heat shrink connections. All that is missing is a button for in the cab and the wiring from that button to this horn relay. You do not need a lift to install it and I made this video about the installation. Only thing I would do different is I would get with Kleinn and order 2 more air solenoids to add so that all 3 trumpets come on at once maybe a little higher PSI cut off switch...this would make it more obnoxious.
6350RC fully submersible 100% duty cycle 150psi compressor
3 gallon treated storage tank
Beast 230 triple horn set
All brackets/bolts, spares, etc
Coily hose and zippered storage bag
Kleinn lists these for $1,149 + S/H I am asking $850 shipped
Videos of the actual horns installed in my truck
Status
ManBOOYA
