Emittim3
My '23 2500 Cummins has LT275/70 R18 as stock tires. I'm due for replacement. What is the largest size people have gone with on stock wheels and suspension on their '23 2500's? Wouldn't mind going a little larger but without needing lift or after market wheels with different backspacing.
Thanks!
Thanks!
, I ended up going with 305/65/18 Nitto Grappler AT's and don't have any rubbing at full steer. Definitely looks MUCH better as the tires fill the gaping front and rear wheel wells a bit more and there's a slight bit of additional width vs the stock size of 275/70/18 (plus the Nitto has a bit more tread lugs on the sidewalls). Since we're not talking about a huge jump in diameter I'm not worried about speedo differences. Fuel economy thus far seems to be quite similar as well. The ride is WAY better given I was on nearly bald tires, alignment was off and balance was cruddy at higher speeds. Always a great difference having new tires in the overall ride. The Nitto's, as well, don't have much higher road noise despite the aggressive tread pattern (to me they are closer to a mud terrain than an all terrain).
