Leak
kevin richmond
Friendswood, tx
Hello, I purchased a 2019 ram 1500 4x4 sport a couple of months ago and so far I love it. Yesterday after driving home from work I pulled in the driveway and then noticed a drip coming from under the truck. I crawled underneath and saw that the leak was somewhere above a heat shield on the passenger side. The fluid was red and did not have an oily consistency to it. I did have any warning lights or high temps or any other problems I could see. We drove out to eat and I checked the ground for leaks after. None found. Drove back home, parked, checked this morning, no leaks?? Any ideas would be appreciated. Thanks.
RamCares
n/a
n/a
Hi kevin richmond,
We understand why this may be concerning. I am unable to determine what fluid this might be as I am not a trained technician but if you find that this fluid re-appears, I suggest having your dealer perform an inspection on your truck. We're available via private message if you would like any assistance with this.
Lydia
Ram Social Care Specialist
