Leave 2.5 leveling kit in with 6 inch lift can it be done
Bighorn150
Im wondering if anyone left there leveling kit in on top of the 6 inch lift my leveling spacer is in the strut not on top on a 4 gen any help would be addreciated thanks
1500ram12
5.9L Cummins
Generally people will ditch the spacer and get adjustable bilsteins.
Sent from my SM-N920V using Tapatalk
B
Bighorn150
Would it hurt my front end do you know. i know the rams always sag in the front with suspension lifts
quietpeen
2021 TRX
Hellcat
I might be wrong but won't leaving the spacers in make it nose high?
1500ram12
5.9L Cummins
I believe most lift kits come with a rake. Usually around 1.5"-2" or about the same as the factory rake. Although generally most kits are 6" in the front and 4" in the rear to account for the rake it doesn't make the truck level. Leaving a spacer in my leave you nose high. Adding adjustable bilsteins will allow you to get the truck level
B
Bighorn150
I like the front up hight more then the back
B
Bighorn150
Yeah rather front up a bit rather then the back
