LED bed lighting... anyone have it?
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
my window sticker states led bed lights were a $100 canadian peseo add on, so to have them added by dealer afterwards would be well north of that price.
dknain
Moorhead, MN
If you added your own bed lighting, where did you tap into for power?
I didn’t want to tap into my brand new trucks wiring so I ran back to the battery. $25 kit from Amazon plus spare wire and connectors I had laying around in my garage. 5’ LED strips are in the clamps that hold the tonneau cover rails. Switch on the upper left by the lever to open the tonneau.
Instead of running a wire back from the battery, tap the +12V from the trailer 7 pin wiring. That's fused for 30 amps under the hood, add a lower amp fuse for the lights. If you don't want to tap the truck wires, buy one of these an tap into it:
CURT 56584 https://www.amazon.com/dp/B007EA6WQU/
This will also give you a 4/5 pin flat to run a tailgate LED light bar if that's in you list of mods.
California
HEMI 5.7
Just called dealer to see how much for 2020 led bed light kit and how much to install. $180 for the kit and roughly $450 to install....yeahh no thanks!
KeithP
Hemi 5.7 VVT
https://www.moparpartsonsale.com/oem-parts/mopar-bed-light-kit-integrated-on-off-switch-82215795ab
If you’re a do it yourself’er, this is the complete kit including factory wiring harnesses and instructions. $450.00 to install tells me they just don’t want to do it. Dealer installed mine. Mechanic said it took him two hours. I considered doing it myself but negotiated having the dealer do it in the the purchase agreement.
xemrac
S. Texas
6.7 Turbo Diesel
Looks like the kit above is no longer being sold. I am researching a DIY add-on and have found the following, listed separately on Moparparts:
Bed Lamp Switch - Mopar (68367545AA)
Truck Bed Lamp, Right - Mopar (5182672AA)
Truck Bed Lamp, Left - Mopar (5182673AA)
I still haven't found the wiring harness and/or power connections; any help there would be appreciated!!
KeithP
Hemi 5.7 VVT
It says it’s on order hold until June 1/2020. This isn’t the only part/kit that is on hold until then. I’m not an industry insider so I don’t have an answer as to why but it seems like it’s the harness that’s holding this particular kit up. Production or shipping issues are the likely culprits.
Wadejesu
Alabama USA
Factory lights are about 1 lumen brighter than a key chain light, I added my own straight to battery HI intensity lights, Much cheaper and better than factory and you don't have to have a dealer enable anything. I think I spent 40.00 bucks total
Glenn54
Deep East Texas
Can you supply part numbers or link? Thanks.
NapaRam
Napa CA
Hemi 5.7 L
I am going to add the lights to my 2015 since it has the cut outs in the bed but in the meantime I have been using these and honestly they work great. Very brights and since they are magnetic I have them attached on the inside of the truck bed. More versatile than fixed lights really.
noraa73
