LED bulbs?!?!?!?
Pmed499
STL
Im sure this dead horse has been beat repeatedly, but I’m looking to upgrade to LED headlights on my 07 1500 SLT. Most reviews I’ve read note flicker problems with the low beams even with resistors. Looking for recommendations? Again sorry if this is a repeat post? I’m new here!
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
My understanding is, as long as you go with a good quality bulb, you shouldn’t have any problems with flicker and stuff like that.
I’d recommend the LED bulbs I used for the highbeams in my 4th Gen that have been absolutely wonderful but apparently the company Vanquish Auto where mine came from, went out of business not too long ago.
There’s other good brands that members on here have used without problem, I just can’t remember what they are so hopefully you’ll get more people on here to point you in the right direction.
OCDTech
Louisiana
I'm sorry don't know alot about this, but i can tell you i read on here somewhere, i believe in the alpha obd thread that there is a setting that you can change but you have to have the alpha obd app. Also i don't know if this will even work on a truck of yours age. If i find it i will post the link in here.
joelmic
stl mo
2022 Ram 1500 Big Horn 4dr Quad Cab 4WD SB
My 07 worked just fine with these headlights... https://www.ebay.com/itm/2-Bulbs-H4...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
and these resistors https://www.ebay.com/itm/2x-H13-900...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
No flicker, no delay, just great light
XtremeAR
2016 Ram 1500 Laramie CC 4x4
I have a 2016 1500 Laramie with projector headlights. The stock halogens are the most pitiful lights ever, so I wanted to upgrade to LEDs. I went down the path of AlfaOBD, OBDlink MX, and used an old Android phone to update the settings. (BTW, AlphaOBD is great and Alexey is great to work with!) I went with Hikari "Eyes of Megatron" LED bulbs, followed the guides for changing the configuration settings to LED lights and all was well. Until, of course, low beam light errors started showing up. Dang!
Hikari makes CANBus adapters and I tried those - no joy. I have tried all possible combinations of settings in the configuration and w/ or w/o adapters, all still throw codes... But, I did notice something unique: I get codes (and lose my low beams) only during the daytime. If I start before sunrise or after dark and the lights come on immediately, they would stay on without throwing codes. To verify this, I have spent the last couple of days doing more troubleshooting: whenever I drive the truck, I alternate putting a piece of cloth over the light sensor on the dash (so that the automatic headlights would stay on) and removing the cloth. The results are fairly conclusive - every time the cloth is in place at startup, no error codes. Every time the cloth is removed (during daylight hours), low beam error code. Again, this is independent of whether the vehicle configuration is with or without LED low beams selected and with or without the blasted adapters.
Anybody seeing anything similar with LED headlights and their CANBus?
Smokeybear01
Army
US-NW Coast
Cummins 5.9
I just stuffed some LED headlight bulbs (9007) in my '05 that I got off ebay for $12. and no flicker, but I also didn't have any high beams. Turns out the led bulb pigtail was wired different than a std halogen bulb. After changing the wiring on the pigtail, they work fine and are much brighter than the halogens. So in my wisdom, I decided to upgrade all the exterior lights with led. Checked a socket in the rear and determined they were 'CK' wired sockets and ordered the bulbs and resistors. Turns out, the front signals are Standard sockets and I blew a few fuses before I figured that out. Just recvd my 'Std' leds and will be installing them in the front tomorrow. Are we having fun yet? haha :Stupid Me:
