LED light bars in bumper
swine
NE Indiana
Well, I finally got around to putting LED light bars in my non-Sport bumper. I used the tow hook openings in the lower bumper. Obviously the tow hooks had to be removed, but it didn't really matter to me. I had my other truck for 10 years and never used them.
I ended up getting 9.5" Amazon specials. I actually tried a couple a different sizes before ending up with these. These were the largest light that I could fit without doing some serious fab work. The bracket behind the bumper is the limiting factor on the width.
I made a couple of simple mounting brackets out of angle iron. These I mounted to the existing bumper with a couple of bolts. I had to drill two holes through the bumper support.
I didn't really like the look of the lights as they came, too much chrome. I remember seeing another member that had painted the reflectors and liked that look so that's what I did.
These lights also came with an acrylic lens which I replaced with lexan. Given how low the lights are I figured the added impact resistance would be a good idea.
I'll try to get some output pics tonight.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
How did you wire them in?
Sent from my LG G4 on Tapatalk.
swine
swine
NE Indiana
They're wired to my Switch-Pros panel.
http://www.ramforum.com/f51/switch-pros_install-82040/
The controller handles all relay functions and keeps me from having to run any additional wires into the cab. Run the switch panel connector once and then everything else stays under the hood. Easy-peasy.
For the wiring itself I used weatherpack connectors to make all the connections and used 16ga SJOOW from the lights to the controller.
sbarron
Wasilla, Alaska
Wish I would have realized things like this were around when I wired mine. As I'm getting ready to add a bunch more lighting, I'm now thinking I need to redo the original wiring and use something like this.
swine
swine
NE Indiana
I discovered it while searching for an alternative to the Carling switches. I'd already bought some switches and had a relay panel/fuse panel also. I was having a heck of a time figuring out where to put relay panel as it was kind of bulky. I really liked the Carling switches, but I didn't want to cut into anything in my interior to mount them and several ideas that I had for fabricating a mount didn't pan out.
All this sent me back to the drawing board. The SPod is a neat solution for underhood, but still uses the Carling switches. Once I saw some of the info for the Switch-Pros I was sold. It won best new product at SEMA in 2015 and I can see why given all it does. Eights switches is way more than I need right now, but... never say never.
BlownGP
Houston/Baton Rouge
Wow, thats pretty bad ass..How much does that thing run?
txcobowhunter
Cabool, MO.
2016 SSV
Looks really good. You know you jinxed yourself right? I foresee a need for the tow hooks in the near future.
sbarron
Wasilla, Alaska
Haha. Has anyone ever "needed" the tow hooks?
Mpgrimm2
SC
5.7L
Got a link to those 9.5" Amazon LED's?
heefageLA
Vidalia, LA
05, 14, 17, 20, 23
Bringing this thread back from the depths.
I just did this mod and am pleased with how it turned out... Except for one thing.
I had to do my mounting bracket a bit different and I don't have very much adjustment.
Rather I should say, I have zero adjustment on the lights.
I built my mount so that the light bracket bolt is mounted flat or horizontal behind the light rather than vertical underneath the light like most mounts you see. (Sorry no pics)
Right now they point too close to the ground, and my adjustment swivels are maxed out.
My question to Swine is, "If I build some brackets like yours will I be able to fine tune the direction of the light output?"
Also, it being several months down the road after your install, are you still happy with how it turned out?
swine
swine
NE Indiana
I considered placing the mount behind the light, but as you've discovered, it doesn't allow for enough adjustment. Mounting from the bottom will solve that. I also left enough space between the light housing and that annoying bumper bracket to position the light without hitting anything.
I'm pleased with the way it turned out. I don't think I would do anything different.
HemiPower36
CA
2014 Ram 1500 Laramie 4x4 3.92 8-speed
Any word on this? I just feel that threads on lighting mods must also have some night shots :)
noraa73
