LED lights behind grill
S.Dodge
I'm looking to add some LED lights or light bar behind my grill. I have a 2015 1500 outdoorsman with a honeycomb grill. I don't have the gap between the tow hooks like my 3500 did. I drive alot at night back and forth from work, 12 hour trips and mostly at night. I want to leave the active shutters installed because I may be trading the truck in soon. Has anyone done this without removing them and if so, what type of lights did you use.
tron67j
Maryland
I bought brackets that go behind the tow hooks to mount my fog lights. I bent them to work for my needs. Maybe search for the brackets and see if there is a version that works for you. Good luck.
S
S.Dodge
You mean you replaced your fogs with led lights? Do you happen to have pics? I did see some led fog lights but I'm worried about them being so low and driving on dirt roads they will be covered with dirt and mud real fast.
