Left rear wheel.
suzukiquadrider
cummins 5.9, 6.6 duramax
i just put new rear brake pads on my 2002 ram 1500. disk brakes. when i am driving around 10 mph i hear a squeek coming from the left rear wheel. is it the pads i put on? did i do something wrong? is it normal for new brakes? the thing that confuses me is i dont even to have to press the brakes to hear the noise. only coming from the left side.
the only thing i did different on the left verses the right was i had to reuse a clip, and the center tab on the clip is bent all of the way back. but the brakes work so i am confused.
thoughts opinions?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Is that center tab rubbing up against something that is spinning?
suzukiquadrider
suzukiquadrider
i re took the wheel off and bend the clip all of the way back and it does not rub but the noise still continues.
BlackedOutHemi
DFW, Texas
2012 & 2012
Check for anything that is possible to rub, check the inside of the wheels for any circular marks going around it. That would be my first suggestion.
suzukiquadrider
suzukiquadrider
when it gets light out side tomorrow ill crawl under the pickup and attempt to look for markings or anything hanging up.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Also check you parking brake pads. They could be pressing the inner part of the rotor. Just a thought. I had a squeak like that when I did mine and I had to replace those clips on the caliper to get it to stop.
Droid Incredible 2 on the move!!!
suzukiquadrider
suzukiquadrider
So i should replace that clip i'm reusing? and the parking brake pads are on the caliber somewhere?
thank you for all of the replys!
quietpeen
2021 TRX
Hellcat
Did you check to make sure the pads move freely and lube them?
suzukiquadrider
suzukiquadrider
no and no i had never done brakes before. next warm day i will take the rear wheel off and try that.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Anti seize the slide pins an the e brake might be dragging do you turn them in
quietpeen
2021 TRX
Hellcat
Sorry in my posts I meant pins not pads. If a pin is seized the pad can rub and squeak
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
it's better to. The parking brake it's in th inner part of the rotor. Were the rotor sticks out, the parking brake pads are inside there.
suzukiquadrider
suzukiquadrider
When i take the wheel off i'll look for those, ive only used the parking brake once and it stuck so i have not touched it since.
