Level with zone 1.5" body lift pics
Wramey
I went with the fox 2.0s with the factory 2” setting and haven’t had any issues yet. I had them on for a couple months (~8000 km) and then had my front end inspected and the shop said everything was tight. It feels tight as well so no issues to report. I wanted the icons as well but decided the extra cash probably wasn’t worth the difference in ride quality, I’ll guess I’ll never know lol.
Do you have a 13 or newer just curious because I know the 09-12’s are solid.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
can you do save time during install if they are done at the same time, or is it 2 separate install procedures? I'm going to level, and lift so while I'm doing the level, can I also lift?
Pa.hemi.ram
Pittsburgh
Hemi 5.7, 6" Rough Co lift, Fuel wheels, Bully Dog Gt, K&N CAI, Magnaflow Exhaust
Any gaps in your running boards with the body lifts?
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
the running boards attach to the body. so, no. the amps required a little bit of trimming on the frame mounts. nothing major though
shadowhawk
Southeast WI
oh.. ok. Thanks
shadowhawk
Southeast WI
I'm trying to do the math, so if someone could double-check my addition.....
Bils at 2.8, plus a 1.5" Zone body lift should get me 4.5 inches lifted in the front. I plan to put a rear spacer on, too. I also want Falken Wildpeaks- 35x12.5r20. So all in, that should give me 5.5 inches total lift over my stock setup, right? I'm running 275/65 now on stock suspension.
Express SN95
Maryland
After the Bilsteins settle you would have about 4" of lift up front. I think with tires you split the difference, so you wouldnt actually get the full 1.6" of added height compared to stock tires.
Sent from my LG-LS993 using Tapatalk
shadowhawk
Southeast WI
everything I've seen says Bils at 2.8 gets you 3 inches lift. and I was splitting the difference on the tires.
bchap05
I think my bils at 2.8 probably ended up at more like 2.5. But I forgot my initial measurement
Reactions: JB1
Express SN95
Maryland
Really the only way to know is take measurements before and after. Bilsteins and the body lift will look good with the 35s. I think overall you'll be looking at just shy of 5".
shadowhawk
Southeast WI
well, only problem is when I do it, it will be in my garage. I need to be able to get it out of the garage. Tires will be last.
bchap05
My garage is pretty standard size and my Silverado with 6inch and 35's fit by like 1/4 inch so I'd think you will fit.
shadowhawk
Southeast WI
There are a few others that have done the same. I tend to agree, but I'm a bit cautious.
Tpearson515
Saco, Maine
Zone 1.5 body lift and 2.5 front level with 1.5 rear spacer,
First picture is level kit only with factory tires8191a9a4641a6c40c52dba25d3dd4279.jpgbbcef4505d15a2ccb2260599433630e2.jpg88f61805da7e2deb84b9e9469b734e0e.jpgf110903d37c071d1b53b1749d2d4cec0.jpg
shadowhawk
Southeast WI
Pearson, can we get a nice side shot of the truck?
shanmccarthy
