Leveling kit advice
rjwilk4154
Lagrangeville ny
hey guys I recently posted about doing a 6” lift on my truck. But the more I learn the less I want to go with the rc 6”. I’m thinking of doing a 2.5” leveling kit. I’m looking to fit nitto ridge grapplers on my truck-
35.4x12.8R20 - 325x60R20
I’m going to be keeping the stock wheels (20x9).
-will they fit with 1” spacers?
And I would also love some recommendations on what leveling kit/ spacers to go with, if I go this rout.any other recommendations would also be greatly appreciated
BOWERSFJ
Uniontown OH
The 1” spacer will allow the tire to clear the UCA, but otherwise, that’s a lotta tire for just a level ... Gonna look pretty “stuffed” and may rub in a few spots ... Ever consider just a 4” lift ?
DustanT
5.9l 24v cummins
I went with a bilstein level thinking it would make a bigger difference than it did and was kinda disappointed. Now looking at a Zone 6" and 37's. why 6" because it doesn't cost much more and the tires are also close in price too, glad I have 92" to the weather strip on the garage lol
JoshR104
If your doing a level check out Thurens. I had them on my old 1500 and rode like a Cadillac/sports car almost with the 2.5 kings. The wheels were 0mm offset with 35s.
Its expensive but def worth it for the ride.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
I wouldn't recommend running 325/60/20's with only a leveling kit. It's simply too much tire and you're going to have rubbing issues no matter what. You'd be better off sticking with a 35x12.5 which runs a little smaller in both height and width.
For spacers, you'll need a minimum of 1.5" to clear the stock studs. With 1" you'd need to trim the end of them off; just an FYI.
For a leveling kit, Bilstein 5100 adjustable struts are going to be one of your best budget options. They're a far better option than spacers for not much more money.
joshhhh
