Leveling kit
TKsHemi
I have a 2008 Dodge Ram 1500 with a 2.5 inch rough country leveling kit with stock wheels and tires. I need to know if I can run 35/12.50R20 tires and 20x9 wheels with -24mm offset with just the leveling kit? Thanks.
rebeltanker91
Fort Stewart, GA
5.9 Magnum V8
You should be able to run 35s id check how much space you have befor you hit the upper control arm. I have a 3 inch level on my 02 which has torsion bar suspension and with 10.50 inch wide 33s and I can snugly fit my hand between the tire and the arm.so you might not be able to run much wider tires but it should fit 35s. You can measure your clearence all around to figure it out.
