- Joined
- Nov 3, 2011
- Posts
- 8,366
- Reaction score
- 7,542
- Location
- Houston, Texas
- Ram Year
- 2017
- Engine
- Hemi 5.7
Any fender measurements?
Jb1 heres his fender numbers. The rear end is 2" higher than my stock measurements. I'm curious about your bumper as well. Even with the level installed your front end is sitting pretty low. I think we may have a candidate for the eibach strut and coil setup set to the 3.5" (heavy bumper) setting. The angles look good, and with a set of ucas he should be fine.So the front is 23" from center of wheel to fender edge and the rear is 26" from center of wheel to fender edge. Its 7" from top of tire to fender edge in front and 10" from top of tire to fender edge in rear.
So the front i cant get a good picture of the puck but they are from supreme suspensions and its a 3.5 inch leveling kit i know because i installed it. But there is a picture looking up inside the rear coil and a picture looking at the puck the best i can get.Rear looks OEM with Fox shocks, so that’s stock height. However, we REALLY need to see the upper portion of the rear springs. Use the flash on your camera or another light, as it’s hard to see in your pics. The front strut is definitely OEM as you can see the Pentastar logo. What we need to see is better pics of the top of the front struts/coils to see what kind of pucks/spacers you got up there.
Okay i will check for spacers in the rear next if there is any i will pull them and hopefully that will take care of that issue. Thank you guys for all the help if i need any more help i know where to go!As GIJoe stated I'd say you have a 2" spacer back there. If you're happy with the ride you have up front, your best bet is to pull the spacer and get it back onto the oem height. From there you can truly decide what, if any changes you want to make. There's tons of options out there. Eibach, bilstein, icon, sd truck, carli and I'm sure others all make coils for the rear and there's plenty more choices for the front. But you're gonna be chasing your tail trying to correct the front when the spacer size in the back would keep it level at 4" of lift.
Report back on how big that spacer is out back. What front bumper do you have on your truck?Okay i will check for spacers in the rear next if there is any i will pull them and hopefully that will take care of that issue. Thank you guys for all the help if i need any more help i know where to go!
Im not sure it was on there when i bought it. Pretty sure its just an amazon special called a superdrive rock crawler. I found it looking for a different bumper for it. LolReport back on how big that spacer is out back. What front bumper do you have on your truck?
I was qondering if thats possible but i didnt know if that was a thing or not... I mean i dont really haul anything so it wouldnt matter i just wasnt sure if that was safe!If there is no spacers in back what about cutting down the Coilsprings in back a little? If you’re not hauling heavy loads?
