level kit
  1. B
    Air delete kit with spacers
    I am finally removing the air suspension on my 2019 1500 Laramie longhorn 4WD. I am going with the standard airdelete.com kit. I am deciding what to do about the spacers. The kit I ordered comes with removable front and rear (4) 1” spacers. I also have 1.5”, 2”, and 2.5” front leveling kit...
  2. M
    2020 Ram 1500 Classic tradesman 2WD lift ??
    Hi everyone , first truck here: 2020 Ram 1500 Classic tradesman 2WD Have many questions!! I am wanting to lift it around 2 - 4 inches... Not sure what to do or go with ? I am seeing alot of leveling kits which gives a 2 in lift as well , but have heard that they are bad in the long end ? What...
  3. M
    Suggestions for lift/level
    Hello all, I was looking for some recommendations, I’m in the process of up-sizing my tires on my 2018 ram 1500 and trying to decide which route to go. Currently have 270/60R20’s and am going to upgrade them to 275/65R20 Nitto trail grapplers I don’t really wanna put spacers on, so the main...
  4. T
    Upper control arms
    Hey yall new here just got on here because I couldn’t find info really anywhere else I just bought a 98 2wd dodge ram 1500 single cab long bed base model it’s been resin with some small rust that is fixable with wire and buffer but needless to say I’ve got my lift and everything picked out I...
  5. H
    Ride quality
    I have a 2024 Ram Rebel 2500 with a 3" level kit and 37" tires. Issue i have is when driving it feels as if the truck is twisting when A: crossing center line, or B: when hitting small bumps. severe enough you can see it in the whole truck in the mirros. Question is would an adjustable track bar...
  6. J
    2015 ram 2wd lift question
    I've got the RC levling kit and now i want to get a lift kit what are my options? Can I just get spindles?
  7. S
    Suspension Upgrade!!
    2014 Ram 1500 Laramie. Just wanted to share with you guys my favorite suspension upgrade I’ve done on my last two rams and about to install on my latest now that I have everything delivered. First, it is not a lift kit. I’ll start with 2” N3 leveling struts and N3 shocks from Rough Country, I...
  8. Kenleighheat
    2019 Ram 1500 Limited Level
    I need advice on a level and tire set up! I have a 2019 Ram 1500 LIMITED with the air ride suspension and all the extras you could ever have on these trucks. I am looking for advice on an affordable and good quality set up for a level kit and wondering what size mud tires I can have with a...
  9. A
    Level kit
    Thinking about getting a level kit for my 2020 1500 but a little indecisive on how many inches. Was originally going to get just a 2” for the front but recently seen they offer 3” for the front and 1.5” for the rear. Does anyone know if that 3” and 1.5” would make it all around leveled with an...
  10. G
    Front suspension lower
    I have a 2013 1500 with 60,000kms. After installing Bilstein 5100 and bags in the rear, the front sits slightly lower. What is the best way to fix this and level the truck nicely?
  11. Z
    The Dangers of Leveling Spacers - 1500
    Hey all, first time poster, long time lurker. I wanted to share my experience with leveling strut spacers on the 1500 series trucks. Before installing my leveling spacers, I knew that the ride would not be as good as a full leveling strut, but I never saw anybody talking about the long term...
  12. T
    suspension air bag sensor issue
    I have a 2017 Ram and recently had a leveling kit installed. My air bag suspension sensors keep popping off and the warning light keeps coming on. The dealer is trying to tell me that the sensors are now over extended and I need to get an extension for them. Do they even make such a part? I...
  13. R
    Leveling Advice - COMPLETELY LOST!!
    I've read almost every post and called a few shops in MN and now I'm even more confused. I'm not looking to add a crazy lift kit as all I'm really trying to do is remove the factory rake out of the truck, and create a better stance. What I have '21 Night Edition w/o air ride. Tow a large boat...
  14. Boohoops
    What size wheel spacer?
    So I recently bought Toyo MTs 35x12.5R20 for my 2012 1500. It has the bilstein leveling set up on it. I also have aftermarket rims but I don’t know the actual offset as they came with the truck when I bought it. I now rub on the uca’s at almost full lock. Makes parking lot maneuvering a b*tch...
  15. K
    18 ram 2500 leveling help
    I'm looking at putting a leveling kit on my 2018 ram2500 6.4. I found a 2.5 rough country with shocks and was thinking of getting it. And I'm looking at 20x9 fuel assault for it. My question is with 2.5 in the front should I get a 1" spacer in the back also or will it sit level without it. I'm...
  16. H
    2WD Bilstein 5100 Help
    I have a 2WD 5.7 1500 and want to level the truck without using spacers, and was pointed in the direction of the 5100 Series shocks. My buddy says the shocks will not level the truck, but after a phone call with tech support at 4 Wheel Parts they say it will. Anyone have any experience with them...
  17. wkirklandco
    New Jack for lifted 1500
    I just realized after leveling and putting 33" tires on new wheels that my stock scissor jack will not even get the tires off the ground. Any suggestions for a new jack that will actually lift the truck in case I get a flat? Will a 2500 jack work in getting the tires off the ground? Thanks all!
  18. DamnRam1500
    Rough Country 2.5” level kit with 1” rear spacers
    I’m selling a used RC 2.5” level kit for the 09-2020 Ram Classic 4x4 models only. The kit has about 30k miles on it and is rusty but that’s powder coat for ya. The kit comes with strut preload spacers (you must disassemble the strut, install spacer and re assemble the strut. Then the shin...
  19. Walke405
    Level kit.
    Hey guys I am looking to get a 2017 Dodge Ram 1500 Laramie 4X4 and the first thing I want to do is level it. What would you recommend I get to make sure it looks good and rides good?
  20. J
    Another will they fit question.. lol
    I’m finally doing my bilstein level this weekend and now it’s time for bigger tires! I want 315 70 17 on 9 wide rims with no offset I can’t find a straight answer anywhere. If they will fit without rubbing I know the height will be fine I’m just worried about the width? Any help would be awesome!
  21. J
    17” rims
    I’m looking for some ideas for tire size on my 17x10 fuel rims not sure if I want to level it or not. Got 265/70/17 right now, and I think they look a little small..Want to see what looks good with 17”rims if anyone’s got some pictures for inspiration
  22. HD_Lineman
    Level kit pics & suggestions
    Hi everyone, I’m coming over from an f150 which I had a 2” level coil spring spacer on. I drove over 125,000 miles on that set up and loved it and never had any problems. Now I have a 2017 2500 Laramie with the 6.7cummins. I am looking for some suggestions on which level kit and type of level to...
  23. T
    Customization Shops
    I have a 2018 2500, with 6.7, live between DC and Baltimore. Looking for a local shop that can put a leveling kit/wheels/tires on the truck. Any recommendations appreciated.
  24. WillH4th
    Leveling my Ram
    Looking to level my ram 1500. I have a ‘17 hemi quad cab. Honestly just looking too level it and run the largest tire I can on stock 20s without doing spacers. I was checking out the bilstein 5100’s but seen previous years talk about ball joints popping out unless you change upper control arms...
  25. L
    Leveling kit
    So I have a 2016 ram 1500 5.7l hemi I want to level the front to the rear but I was reading stuff last night that if I leveled up front it’ll give a permanent camber issue that can’t be fixed but I want to know if that’s only for a certain height the back of my truck wheel well from ground to...
Bob Templeman
