LF Tire rub
MLTRam
Recently blew out a left front tire and bent wheel. Replaced wheel/tire, now alignment is way off and side wall of tire is rubbing on upper control arm. Heading back out tomorrow to get another look. Where to start, bent upper control arm? ball joint?
Thanks
Daw14
South Florida
Tie rod sounds like it took a hit, have your alignment done, make certain they straighten the wheel .
huntergreen
Marine Corps Navy Badge
I’d have it aligned and let the folks at the alignment/front end shop tell you what needs to be replaced.
