lift and tires help.
jeison33
In have a 2010 dodge 1500 crew cab and looking to buy the maverick d538 20x12 -44 35x12.50 tires . How much lift do i need? What are some decent lifts i can find or can i just do the bilstein 5100 series shocks ?
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
You'll need at least a 4" lift to even think about clearing that setup. But trimming would be required even at that. If you don't want any rubbing issues at all you'll need to go for a full 6".
J
jeison33
Which lift should i go with?
JCJ4290
2014 CC 4X4
Depends on your budget. He's right, you'd need a bigger lift to clear tires with wheels that wide. Zone is pretty affordable, I've used ProComp before and had a great experience with it, Sky Jacker is pricey but well built, and Rancho is pretty expensive as well but people seem to love them. A 6" lift isn't too difficult to find, it's just all in the budget.
brandonjansen
Zone makes the best "bang for your buck" lifts IMO. Any of their kits will work for you, all depends on exactly how you want the truck to sit and how high you want it to be.
360 Man!
5.9L
Hello, Just curious does any body have pictures of a t bar crank lift. Meaning 3" or 2" rear lift blocks and maxed out front t bar keys?
Thatdude596
buckeyes state
2009 ram big horn
With those rims and tires your gonna want a 6" lift or 4" and a leveling kit
