Lift increase to 10"
mcompany
Canton, OH
2011 Power Wagon
Hey y'all
I just got quoted 1200 bucks to take my 6" kit and turn it into a 10" kit? Does that sound reasonable? I am kinda in shock I expected way worse
1500ram12
5.9L Cummins
Depends on how it's done.
Sent from my SCH-I605 using Tapatalk
Stangshcky12
Oshkosh, WI
5.9 Cummins
I'd ask how they plan on doing it
Most 8"+ kits are long arm kits with dropped control arm brackets
You would need to get a different track bar bracket, sway bar end links and pitman arm
Basically a whole nother lift kit to do it right
1500ram12
5.9L Cummins
He has a fabtec lift so he probably could add 8" Springs (depending on his kit) bigger blocks in the rear and either 1.5" or 3" body lift.
mcompany
mcompany
Canton, OH
2011 Power Wagon
I have the 6" fabtech long arm kit with trac bars. I was told by fabtech that I cant make it bigger. I call *********. So right now, I am looking at a 3" body lift from PA I know that it will affect use of my winch, and frankly, I do not care. So, I am thinking 3" body, with 8" springs longer shocks, progressive leaf rears. Would this work?
