Lift Kit Help
Brandonk305
First post...apologize if I did anything incorrectly.
I was looking to get a 6 inch Rough Country lift on my 2019 Ram Classic. The only question I had is are the 20 inch wheels actually required for this kit? And why? Rough country states it is on the website but I would like to keep the 18’s that I have if possible.
I appreciate any guidance you guys can provide.
thanks,
Brandon
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Don't even mess around and go with the Maxtrac lift kit with fox shocks my friend ... and I am pretty sure you can use the 18" wheels ....
2018 2wd
As a matter of fact it says it on their site that it will
Description
The Maxtrac Suspension 7-inch lift for the Ram 1500 is a cost-effective way to lift your 2WD wheel drive truck without breaking the budget. We do this by taking a factory height spindle and lowering the wheel hub position, which in turn raises the vehicle up while maintaining a factory-like ride and turning radius. We then install a Maxtrac coil spacer on top of the factory coil spring along with a Fox 2.0 monotube shocks to complete the front lift. By doing this, you eliminate the need to install expensive crossmembers that are labor intensive and require factory frame cuts. The spindles come with extended, DOT compliant, stainless steel braided brake lines. The rear lift comes with Fox 2.0 monotube shocks, rear coils, track bar/swaybar brackets. The end result, you achieve a lifted truck with a leveled stance for a fraction of the cost of a standard 4WD kit.
NOTES:
  • Track width increase of 1" per side
  • 17" Wheel or larger w/ 4 1/2 - 5 3/4 " Backspacing
  • Wheel width 8-9.5
  • Will Clear up to a 37" x 12.50 tires
  • P/N: 612400 required for vehicles with 2-piece
This kit comes with:
P/N: 702145 4.5" LIFT SPINDLES W/ EXTENDED BRAKE LINES DOT COMPLIANT
P/N: 872171F 2.5" FRONT COILS & FRONT FOX SHOCKS
P/N: 902445F 3" COILS, 1.5" SPACERS, TRACK/SWAY BRKTS, FOX SHOCKS
WARNING:
MAXTRAC SUSPENSION DOES NOT ADVISE USING WHEELS WIDER THAN 9" OR WHEELS WITH LESS THAN 4.5" BACKSPACING. DOING SO WILL RESULT IN VOIDING ANY AND ALL MANUFACTURER WARRANTIES
