Lift spindles instead??
firemedic10584
Central Fl
So I've got Maxtracs 2.5" lift coils and shocks on my 2018 sport 2wd to accomplish leveling it. It still isn't quite level with that kit. My issue is this - I've had the alignment done twice now and it's within spec but the truck continues to sometimes pull left and sometimes pull right. The tech at my shop believes maybe the leveling kit is causing the issue(s). So I'm considering pulling the maxtrac coils and going with this 3" lift spindle I found to accomplish the level. the spindles allow everything to stay at factory angles and what not. I found these spindles on Ebay but can't find anyone else who runs them. Would I need longer brake lines with these? It doesn't state that either. I know on the 4.5" spindles I'd need longer brake lines. What do yall think? Any other suggestions??
https://www.ebay.com/itm/Ram-Lift-S...280233&hash=item569be300e9:g:xzEAAOSwq~tZQnyd
F
firemedic10584
Central Fl
And also, when I say pull left or right, it's not just a slight drift, it's a steady pull and I'm in the opposing traffics lane within 2 seconds. So something is definitely off.
