Lifted what gear ratio??
What is your ratio
  • 3.21 with 8 speed
    Votes: 11 32.4%
  • 3.92 with 8 speed
    Votes: 11 32.4%
  • 3.55 with 6 speed
    Votes: 3 8.8%
  • 3.92 with 6 speed
    Votes: 1 2.9%
  • Other.. if running a different ratio post combo
    Votes: 8 23.5%
  • Total voters
    34
H3MI UP
Southeast ga
Just curious for us guys that are lifted and running 35" or bigger tires and guys that aren't lifted but are running a 35" tire what gear ratio you are running. Also how does your truck perform with that gear ratio and have you had any issues.
Ferro
I'm running a 4" with 35s with the 3.21 gears and have no complaints at all.
MADDOG
Out Exploring Arizona
Level kit here with 35's on a 2500 with 3.73 gears.
joeygster
Ancaster, Ontario
I'm running a 4" lift kit with 35s with the 3.92 gears and couldn't ask for more.
Red5Point7
Leveled, 35s, 3.55 gears, 6 speed. Little sluggish up to like 20 mph, anything after that she still hauls
stevens
2015 Dodge Ram sport 4x4 crew
im running 37's and i got no idea what im running....how do u find out your gear ratio numbers?
H3MI UP
H3MI UP
Southeast ga
I crawled under the truck and looked at the rear end on the drivers side. They was a tag that said 3.21. You can also go to ramtrucks.com and put your vin# and get your build sheet and it will tell you
6.7CumminsDrvr
The Dude abides………
Georgia
4" lift with 3.92's & 35's, great combo! MPG's tracked on Fuelly.
Around town is pretty consistent around 13.3 mpg. My "around town" includes VERY short trips in the morning to drop kids off, less than a mile round trip so I don't even shut the truck off when I take them in. When I head into the office and commute my MPG's go up significantly since she actually gets to cruise a bit.
All HWY is between 16-17 depending where I'm headed.
All in all, very happy with what I've got. It's lifted, looks just how I want, still hauls a$$ when I put the pedal down, and will return respectable MPG's if you show just a little restraint.
Jershipe
Monroe Michigan
4" 35's with 3:55's and six speed. Drives fine. 3:92 would be better though. If I keep it around 70mph I get about 16mpg. I do a mix of driving. Average city/highway is about 13 now. But I been letting it run for 10 or 15 every morning and after work
fordtech90
Jonesboro, La 71251
How in the hell are you getting 16-17 at hwy speeds? What speed do you set cruise on and it must be flat?
stevens
k i found out what i got. 3.92 gear ratio. with 37's on a 6" lift.
yillbs
I've got a 6" with 35's and I average 11.6 with curly. What mpg are you getting ?
H3MI UP
H3MI UP
Southeast ga
I wish I had 3.92 over the 3.21 with the 8 speed. I can deal with the 3.21 as long as it doesn't put a lot of strain on my tranny and motor over time and make them fail early. I still have to get use to the low of a gear. It seems from what I read that as long as I have the 8 speed tranny the 3.21 are perfect for 35" tires and 6" lift. Hopefully it holds true
6.7CumminsDrvr
The Dude abides………
Georgia
I'm sure my tune has something to do with it.......
I usually drive between 78-83 mph (when the limit is 70) and that seems to be the sweet spot which is usually just a smidge over 2k on the tach. I do know I get slightly better mileage than if I slow down to 65-70 as the rpm' drop just enough the engine "loads" more. My numbers are legit, all hand calculated and tracked on Fuelly.
I am talking about straight HWY, long trip driving. As soon as I get off the interstate and hit stop an go traffic the MPG's fall quickly.
Oh ya, to be transparent and all I do have "skinny" or "smaller" 35's. I anticipate my numbers going down with my next set as I'm eyeing 295's
And I NEVER use cruise, MPG's are worse when using it
Orca
