hunterdan
- Joined
- May 7, 2018
- Posts
- 1,220
- Reaction score
- 1,647
- Location
- SE PA
- Ram Year
- 2019 classic
- Engine
- 5.7 Hemi
It could take a while for all the lifters to get pumped up and all the noise to go away. Make sure all the pushrods are locked into the rockers correctly and everything is tightened down correctly. It's very possible you may just have to put a few miles on the motor before all the lifters are fully pumped up. Here's a few videos to check out.I replaced all the lifters myself over the weekend. The pushrods still looked flawless so I reused them (installed them the exact way they came out). Torqued everything to spec, soaked the lifters for 4 hours before install, got it all back together, I used mopar oem lifters, and it was pretty noisy on first start up, but it quitened down after about 10 minutes of idling,, but Still have somewhat decent ticking coming from the driver side, going to pull the valve covers this weekend and see if I can find the culprit.... Can anyone explain what this Liqui-Moli actually does?
The NEXT CHEAPEST HEMI on Marketplace Ep6: The #1 MISTAKE People Make Building a Hemi!
The NEXT CHEAPEST HEMI on Marketplace Ep6: The #1 MISTAKE People Make Building a Hemi! On this episode I cover the Most common mistake people make when rebui...
The NEXT CHEAPEST HEMI on Marketplace Ep7: The FINALE!
The NEXT CHEAPEST HEMI on Marketplace Ep7: The FINALE! In this episode we finish the Hemi refresh on our 2003 Ram 1500 and we find out how much it cost to g...
