Light out error message on dash?
blakecarlton57
Martin Tennessee
I have a 2014 Ram 1500 5.7 Hemi, and earlier today I got a error message on my dash. Says one of my front lights are out but they are not. I bought it with LEDs installed on low and high beams. And both seem to be working. One seems slightly dimmer than the other, and occasionally it will flicker on start up. Not badly, but enough for me to notice. Anyone got any ideas?
GRKN
Possible one of the LED chips is out on one bulb but not both/all of them. What LEDs are in there? Pull the headlights so you can inspect the bulbs
Kris Myers
Ontario Canada
If the light is flickering it could be the resistors are failing. This would also cause the canbus system to flag that light as out. Get a normal bulb and plug it in, see if it goes away. if it does you found the issue!
