Laxton1
I perform it's throttle relearn with my scanner after the relearn truck occurred four codes the codes are p2167 p2266
P2216 p2115 and will relearn the idle and cannot clear codes happened on a 2003 ram 1500 57 try to perform a throttle relearn on a 2003 Dodge ram 57 2500 same problem after we learn the same four codes and will not clear . Truck idols good the TPS stays at 16.9 volts and will not relearn
