Limited Slip!?
Custom_Ram
What kind of Rear end fluid are you guys using when installing the LSD? synthetic or not? All my local shops arent using synthetic and dont recommend it? It seems to me like i should use synthetic seems how thats what it comes with
htwo
Waterloo, Ontario
HEMI 5.7
I ran full synthetic in all my diffs with no issue. I'll be changing the fluid out in my 2011 Ram this fall to full synthetic.
C
Custom_Ram
the thing is all the high end brands i would use like mobil 1 or royal purple come with the friction modifier already in it, do you still put some in it? says for high performance rear ends you might need more?
QwikKota
5.7L
Other than an aftermarket TrueTrac, syn is fine.
jag1886
Boise Id Gods country
Demi 5.7 S&B CAI, flowmaster merge collector, Gibson cat back, oil catch can, 87
I just had my LSD put in today and they told me to change it a 500 miles and put in Syn oil and Ford Posi additive. They said they don't know why but ford's is best.
jag1886
You need synthetic and the additive, your shop is smokin bat poop.
Sorry my rear end shop has been in business for 36 years and sure they have rebuilt a few more rear ends than you.
jag1886
I was talking to the OP dude. Not referring to you or your shop.
Guess you should clarify who you are talking to and what you said is still not true.
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
I respectfully disagree sir; I think synthetic with additive is the the best. I just disagree with you, no harm. Wasn't referring to your shop or you, was just stating my opinion. It's an open forum and I don't need to clarify $hit to you. :flipthebird:
hemihustlin
Lower Southwest Quebec
You guys are both saying you need syn and additive, why the conflict lol?
QwikKota
5.7L
Synthetic is best for anything but a TrueTrac. With new gears you want to run cheap conventional for 500 miles and avoid towing or anything that will heat up the diff. After that, drain and replace with synthetic. Run that at least 25k miles or more or you are wasting your money. Clutch style LSD's require the additive, no questions. However, some are stating the new Anti-Spin is a gear type. That I cannot comment on.
fasthemiram12
Eagle 5.7 vvt
New ZF LSD is clutch type still... It is encased and cant be seen like the old style 9.25 lsd
Friction modifier required.
jstacey8
hiram maine
Ok well I have a question. What oil would be best to make it catch posi in the new zf axle or is it possibil to put in a different clutch pack or in a different order?
