Link to bully dog install
2batruck
Does anyone have a link or advice on how to install the wiring for the bully dog hemi install. A guide where to run the wires and the fuse to use etc. Dodge ram 2013 model. Thanks guys.
scottie d
Devine, TX
I just turned my key on and tested a fuse in the fuse box. Found one that worked with key only it was a 10 amp and used the supplied fuse holder. There should be something with the bd or did u buy it used?
saintsreturn
Home in St. Pete, FL
2015 Longhorn
EcoDiesel
Run the power wire through the steering boot. No cutting or fancy tools needed. I forgot which fuse I tapped but it can be found by testing. Let me know what you need and when I get out to my truck in will check for it
Sent from this thing in my hand
2batruck
2batruck
So I can't find the part to connect the fuses together. Or it's missing or i lost it. Wonder if I can order it separately. This sucks.
DavidRam
SoCal - Redondo Beach
2012 RCSB
Do you want to hard wire your BD and mount it permanently??
FYI, You do not need to run wire to the fuse to use the tuner...
2batruck
2batruck
Yes I know. But I wanted to hard wire it this weekend.
