Little extra height along with Bils?
Seth_5.7
North Carolina
I currently have my Bils set to the max height, and my CV angles are perfectly flat. Is there any way I could get an extra inch of lift in the front? Like maybe a bigger spring to go in the Bils or even a small spacer to go on top of the strut?
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
spacers aren't really recommended. Why not just go full suspension lift?
Seth_5.7
Seth_5.7
North Carolina
The rear air suspension setup im doing will be pretty close to 2 big ones, so a full front lift isn't really gonna fit the budget, that's why I'm just looking to squeeze an extra inch out of the front
Sent from my SM-G920P using Tapatalk
ScottCantrelle
I’ve got a 2” spacer on tops of mine set to 2.8. The cv angles aren’t too bad in my opinion, the thing I’d mostly be worried about is the angle of the upper ball joint. It’s pretty steep, but I’ve had mine like this for over 6 months with no popping or breaking. Everything I read said not to do it, so that’s something to take into consideration as well. b71712f4756187044ece2fe6f99b0620.jpgcdfa8fa89983593ec07b13e69fa4b33a.jpg
Seth_5.7
Seth_5.7
North Carolina
That actually looks really good! Could you possibly take a pic of the upper control arm ball joint? And also what brand/kind of spacer is it that you have?
ScottCantrelle
That’s the angle that’s going to be the problem, if any. Also, just did a quick measurement and the front is 1” higher than the rear like this. I don’t know the brand of the spacer, probably just some generic eBay one. It was on the truck when I was installing the bilsteins. Figured just to leave it there and get some extra lift.
Seth_5.7
Seth_5.7
North Carolina
Ah, so does the spacer itself measure 2 inches thick or is it a certain size that equals 2 inches of lift
ScottCantrelle
It just literally measures 2” tall. Not sure how much lift it’s supposed to provide.
Seth_5.7
Seth_5.7
North Carolina
Okay, thanks for the info! Definitely helped. Looks like I'll get a spacer and some zone upper control arms to help with the sketchy angle
Ghstrdr95
