Mopar does make repair kits for the PCM C1 and C2 connectors. However as long as the 2 sliding tabs are locked into the PCM, they shouldn’t ever come lose.
68148108AA Is for C1
68404960AA Is for C2
Those are the part numbers for the mopar repair kits.
C1 *PCM*- https://www.mouser.com/ProductDetai...MIqNyvwrOZ5AIVA1YMCh2tMAEVEAAYASAAEgLRXfD_BwE
That picture is the BCM, not the PCM.
The part that I posted is the 24 way connector shell assembly (locks and all) that is used for the C1 connector. You would de-pin all the wires from the old one, and insert them in this one. I’m sure there are more part numbers for the same connector, just a matter of color.Ah, I see now. I got confused...Now I feel better about not being able to find a replacement part.
That's probably the pig tail, but the 'connection clip' Delphi number is 13673600. (I do know that one for a fact). Regardless, it's in stock, and I ordered one. When I looked previously you had to order a full reel, like 1200 or so. Owe you a thank you for making me look that one up!
https://www.mouser.com/ProductDetail/Aptiv-formerly-Delphi/13673600?qs=eUFwbO5xkCilWYDeLRKhOA==
