Looking for recommendations; intake and motor mounts.
Richmond
I’m getting a reman engine Installed in my 06 Dodge Ram 1500 5.7 hemi 4wd. I’m looking on the parts sites and can’t figure out the correct motor mounts, any ideas? Also need a recommendation on an intake for the same engine. Any help is appreciated!
LoneWolf3574
The parts manual has the below numbers as the factory part numbers for all 4WD 5.7L V-8 engine mounts (INSULATOR, Engine MountFront Right/Left). Usually, each of the aftermarket manufacturers has some sort of an interchange catalog, unless you really want OEM, then you're looking at north of $600 for the pair.
55366660AD - Right
55366661AC - Left
Pressing out the inserts is another option and much cheaper, but I have read that is a major hassle to press the new inserts in.
I use MoparPartsGiant to at least figure out if the part is compatible with my truck and I don't have the parts manual handy, they're dead on most of the time.
HemiLonestar
Navy Badge Coast Guard
MD
Intake as in manifold or intake as in filter/inlet?
Brando_SLT
Orange County, CA
Don't do this... You will hate yourself. Just get the complete isolator/motor mount. You have to pull the whole thing either way, might as well just replace them. Also, get the transmission mounts.
