Loose connection - Seatbelt & Airbag light flickering.
dashbarron
Cummins
Have a 2017 2500 that was detailed last year. They cleaned under the hood and the day it was brought home the seatbelt & airbag light started flicking on and showing on dash. Does whenever someone hits a bump. It happens randomly, could be on for 15 minutes, then nothing for a few miles, then back on. It really sounds like a loose connection somewhere.
Any hints where I can find this?
Jeepwalker
WI
2012 Reg Cab, 4x4
Yep. If you hook it to a good scan tool, and go into the SRS or Restraint System (via the OBDII), there should be a code that should tell you specifically what the problem is. It could be any number of things since it's a 'system'. If any of the airbag connectors are loose/damaged, etc, it'll tell you which one (seatbelt/pass airbag, etc). In your case, the problem could be related to the detailing ...or just be a coincidence. SRS connectors and cabling to airbags is yellow, and they're generally very tight locking. But there are modules, etc too. I had a vehicle where a connector at the carpet level near the seat (wires led up to the side air curtain) wouldn't stay locked. Sometimes the connector would work slightly apart. I finally wrapped friction tape tight around it and put a piece of foam to keep it 'tight'. it never loosened again.
It could also be a fuse in the engine bay which either got wet (from detailing), or corroded, or the fuse worked 'up' out of position. There are a number of possibilities, but when the light comes on it'll definitely set a 'code'. So the first thing to check would be to get a scan of the SRS/airbag system. Do this before monkeying with any fuses (which could create no-power codes and throw you off track where to look). If you don't have an appropriate scanner, Autozone or OReilly's should be able to scan it for you. That'll point you in the right direction. Then after that, you can check the fuses. To do that unhook the battery before pulling any SRS-related fuses, which could set a code that the dealer might have to reset, or someone with a really good scanner (that would cost you $$). So, get codes first, unhook battery (and wait like 15 min) BEFORE monkeying with the airbag fuses or any other part of the SRS system.
Good luck
Jeepwalker
WI
2012 Reg Cab, 4x4
Oh forgot to add, per your original post, ..yes, could also be a seat belt or seat switch issue. There's wiring under or near the seat which could have gotten bumped. A scan of the computer and SRS should reveal the issue.
