Loss of power after custom intake?
SmokedRam
Zephyrhills, Florida
Advance timing?
That might help you take advantage of all that air and fuel...
Ch
Sent using XT912 M
Thats what a powerwire does...it's a 4.7K ohm resistor, that splices into the AITS and tricks the PCM into thinking the air is 22 degrees cooler than it actually is, thus adding fuel and bumping timing a little bit.
I have an extra one here.
J
jbrew717
Northern Indiana
I have the magnaflow catback that exits before the rear wheel. Have a magnaflow y pipe that will go on soon. Debating on doing an actual intake or keepin the k&n drop in with the PVC mid pipe. Can I make a power wire or is it easier to buy one?
SmokedRam
You can make one for less than $10.
and here is how...
[yt]qUjAI9ZGXkY[/yt]
bronx79
Montana
Could someone shoot me a list of parts needed for this mod?? and from the IAT sensor wire where does the other end go? Pics would be great also if any body has any. Im new to this sorta thing so if anyone is bored at work and wants to type up instructions id be great full. And this isn't harmful to the engine is it?
bronx79
Montana
on my old 4.7 i had the same issue, it KILLED everything down low. Now with my hemi i made this and she runs really well for dirt cheap!
can you send me your parts list for your intake? i wanna do the same thing with mine and like the look of yours. please and hank you.
NITROUSCHRIS
consumer of excess fossil fuels
Wisconsin
blown 6.1
Sure man! i went to Home Depot and got a piece of 4" PVC about 24" long (in the cut off rack) got 1- 90 degree 4'' elbow, 2- 4" to 3" rubber couplers and a grommet for a 1" hole with a 3/4" ID. Cut to fit, glue together, IAT pushes into the grommet nice and snug. Painted with bed liner in a can and she good!
bronx79
Montana
Sweet! Where did the rubber come from?
NITROUSCHRIS
Wisconsin
blown 6.1
the rubber couplers are in the same isle and the rubber grommet was in the hardware area:****:
NITROUSCHRIS
Wisconsin
blown 6.1
You need the 3" to 4" adapter couplers. The 3" end actually measures 3 1/2 ID which fits over my airbox outlet and TB. I used 4" PVC tube to retain some of the Plenum volume.
